It is currently Tue Jul 08, 2025 5:09 am
PostPosted: Sat Sep 30, 2017 11:41 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I've tried finding the answer to this on here but haven't had any luck, perhaps I'm using the wrong key words.
What causes the cloudy white spots in old-ish instrument finishes? Is it moisture getting underneath?
PostPosted: Sat Sep 30, 2017 1:22 pm
What was the pore filler?
If it was epoxy, it can turn a whitish gray due to blushing I believe after many years creating this type of effect. I'm currently refinishing an instrument with this problem. I also want to acknowledge here that many people use epoxy and that there may be some brands that don't blush like this. I commonly here z-poxy works and I,m sure there are others too.
PostPosted: Sat Sep 30, 2017 3:04 pm
I've seen shellac get kind of cloudy. If you heat it up with a heat gun it'll usually get rid of them. I don't know what kind of guitar inparticular you're asking about but I'm sure we can find a solution for you if we know what type of finish/guitar and such.
PostPosted: Sat Sep 30, 2017 4:10 pm
City: Tyler
My first suspicion is blushing due to moisture. Sometimes it comes out by just hand buffing it with cloth.
PostPosted: Sat Sep 30, 2017 4:17 pm
First name: Conor
Last Name: Searl
City: Duncan
It's a Yamaki, with a lot of big cracks in the finish. The finish seems a little too think to be lacquer, and there's really no checking, like what I've seen in more traditional old guitars. I assume it's some sort of poly. My first guess was that moisture got in under the finish through the cracks.
Users browsing this forum: Bing [Bot] and 2 guests
